Exhaust Manifold Bolts Question >
Old 04-13-2004 | 09:09 PM
Poorsche's Avatar
Lightbulb Exhaust Manifold Bolts Question
We pulled one engine this afternoon and mechanic reports all exhaust manifold bolt heads are badly rusted and need replaced on both engines. The bolts are just at three (3) years old.
I asked about replacing with stainless bolts and mechanic felt that was bad choice--said stainles was too btille and couldn't be torqued properly without breaking bolts...
Is 3 years reasonable life expectancy for these bolts? Is stainless a solution or problem?
While I've got engines out I want to fix everything possible for longest term fix in salt-water enviors..
Thanks-
Poorsche
Poorsche is offline
Old 04-13-2004 | 09:37 PM
formula31's Avatar
well, I dont use any 300 series stainless bolts that have to handle any torque or load, but, exhaust manifolds are not torqued enough to cause a problem with stainless. Ive used them for years. Use neversieze if going into aluminum heads.
formula31 is offline
Old 04-13-2004 | 10:30 PM
Danny_Ocean
Just discussed this very same issue in detail. Feel free to read my recent post:
http://www.offshoreonly.com/forums/s...threadid=75258
ARP makes hardened S/S bolts. Find another mechanic.
D. Ocean
Pompano Beach, FLA
Old 04-14-2004 | 11:27 AM
Merc HP exhaust uses S/S bolts.If you use steel,try to put some kind of sealer on the outside.And you could make sure you wash the salt off those rear bolts.
Dixie Doug is offline
Old 04-14-2004 | 01:34 PM
I have found it useful in many applications to install a couple of studs in each head for the exhaust manifolds. Maybe one each end or so. This allows the gasket to be kept in place easily during installation.
deboatmon is offline
FlashPRace
Do It Yourself, Boating on a Budget
2
03-22-2008 03:04 PM
dogturd21
27
03-22-2008 09:31 AM
vegas daytona
8
09-21-2004 09:29 AM
tmthunder
6
06-02-2004 09:44 PM
32 thunder
2
08-14-2003 12:31 PM
