Alarm Question >
Alarm Question
Alarm Question
Old 02-11-2002 | 12:44 PM
FA18Driver
Question Alarm Question
Hello Gang, I took a look thru all the old posts and didn't see the answer I was looking for. Maybe one of you will know? This weekend my engine alarm started going off all the time. I checked the drive oil and it is ok, my question is, does the alrm unit use the same sending units as the guages? The temp and oil pressure both work as normal but the alarm goes off all the time. Thanks for your help.
Old 02-11-2002 | 12:50 PM
sterndrivespec's Avatar
Post
they use differant senders on the older motors.try to unhook the wires to your drive res bottle.sometimes the switch sticks.
sterndrivespec is offline
Old 02-11-2002 | 12:54 PM
FA18Driver
Wink
Thanks mine are 1995 models if that helps with the sender question. I will try the sender tonight when I get home. Again thanks
Old 02-11-2002 | 02:00 PM
Budman's Avatar
From: Kentucky - where the women are so fast we have to put a governor on 'em!!
Post
Have you been doing any work under the helm? The senders for the alarm work by simply establishing a ground for the energized buzzer circuit. You might have something making contact and grounding it out.
Budman is offline
Old 02-11-2002 | 02:05 PM
FA18Driver
Talking
Thanks Budman, no I haven't but that still could be a problem, as it started as we were out running. Could be a wire fell off and touching something I guess since all it would take is a short to ground of any kind huh? I am going to check the drive res. and then if that isn't it I will open the helm and look and test the circuit with a meter. Thanks again for all of your help
Croozin2
6
02-05-2008 07:18 AM
tommymonza
6
06-27-2007 09:16 AM
madbouyz
6
05-04-2007 10:13 AM
tmthunder
4
09-12-2004 08:33 PM
zokman
4
05-27-2003 07:44 AM
