just off dyno >
just off dyno
just off dyno
Old 04-16-2004 | 08:51 PM
Talking just off dyno
just got back from dyno 454 .30 over dart alum. heads dominator 850 carb dual plane air gap only had time for a couple of pulls turned an avrg of 560 lbs of torq and peak hp 575 what do you guy's think it's going in a 28 scarab excel including the platform. boat weighs 4500 lbs lightened it up aprox 500 now4000 how bought a prop any sugestions????
MS 28 SCARAB is offline
Old 04-16-2004 | 10:12 PM
homan
Try a Bravo 1 24p to start
Old 04-16-2004 | 11:01 PM
Hot Boat's Avatar
Team Dysfunctional
I have the same boat with about the same hP but I got about 75 lb more tork. I am running a 26p prop @ 5400rpm. My boat is loaded with gear and with all the extras it is heavier than when I got it. I would think you should see around 75mph.
what rpm was max HP & tork????
If it aint broke .... I can break it....
Hot Boat is offline
Old 04-19-2004 | 01:26 PM
Thumbs up day 2 on dyno
just hit it 600 lbs of tourqe and 600 hp I kew a little more tweaking would do the trick ready to rock!!!
Old 04-19-2004 | 04:32 PM
28SCARAB's Avatar
MS 28 SCARAB I would try a 26 Bravo or a 24-25 hydromotive. We are going though the same thing now trying to get a 30p Bravo to run at 6000 rpm. with are new Richie Zul motor.
28SCARAB is offline
Old 04-19-2004 | 05:46 PM
Reeking Havoc's Avatar
Default ms 28 scarab
Nice numbers on your 454, what cam you running and what comp ratio you pushin??? good job!!!
Reeking Havoc is offline
Old 04-19-2004 | 08:41 PM
Thumbs up cam
crane cam called saturday night special lift intake 553 exh 571 and duratio intake 236 and exh 246 also looking for exhaust ??? and recomendations??
skaterdave
General Racing Discussion
6
10-06-2008 08:07 PM
deanpp
6
07-18-2007 07:15 AM
tizbad4
09-05-2004 12:54 PM
tizbad4
4
09-03-2004 09:56 PM
Super V
01-28-2003 07:02 PM
