K-Planes battery fuse??
I'm installing K-Planes and the instructions say "a fuse that meets Coast Guard Standards must be installed between the battery and pump motor, inline with the red positive battery lead."
I haven't seen this fuse installed on two brands of boats I looked at. They only have the small yellow-cased 10 amp fuse in the wiring harness that goes to the tab switches. What gives?
Family & Performance Boating (April 2004) has a K-Plane installation article that says they installed 35 amp fuses, but doesn't show what kind of fuse holder or fuse.
Powerboat Magazine (Feb. 2003) has a K-Plane installation article that says or shows nothing about this fuse. They specifically say "per U.S. Coast Guard regulations, we used one cushion clamp every 12 inches", then skips the "Coast Guard Standard" fuse!
So, does anybody have a fuse between the pump and battery? If so, what type of fuseholder, and what amperage fuse.
West Marine carries a nice Blue Sea Systems 30-80 amp "Maxi Fuse Block" fuseholder that looks like just the ticket.
Laketahoe - thanks so much for the research.
I won't be able to look at the pump until this weekend, and I can't see a manufacturers label in the picture of the pump in the installation instructions. I believe it's Oildyne, and it has the translucent white plastic reservoir.
50 amp fuses are available for the Blue Sea Systems fuse block. Is there a web site where I could look at the wiring harness part number you referenced?
BAJA WILL
02-26-2008 08:12 PM
tpmarine.com
New Products and Member Discounts
4
02-02-2006 09:50 AM
