oil temperature sending unit >
Old 04-18-2004 | 07:22 PM
CHAOS REIGNS's Avatar
Default oil temperature sending unit
just got my oil temp gauge
where do i install the sending unit ??
454 Gen IV
thanks!!!
Mark
CHAOS REIGNS is offline
Old 04-18-2004 | 08:10 PM
MACDAD260's Avatar
Charter Member #818
The easiest and I think also the best place is in the remote oil filter pad. This point measures the hot oil coming out of the pan. It will tell you the maximum temp of your oil before the cooler. There should be two plugs on the opposite side of the hoses going the the pad. Remove the plug opposite the line that sends oil to the pad. It is the hose that comes from the outside of the the adapter on the block. The other hose goes from the pad to the oil cooler. Good luck.
MACDAD260 is offline
Old 04-18-2004 | 08:19 PM
I don't have a remote oil filter as of yet -- possibly a future upgrade???
how about without the remote oil filter ??
Old 04-18-2004 | 08:23 PM
MACDAD260's Avatar
Charter Member #818
Here is pic of mine. The remote filter is not in the stock location but, the plumbing is the same.
Old 04-18-2004 | 09:23 PM
migara422's Avatar
Hey chaos, the hatch system its trim master.
Carlos
migara422 is offline
Old 04-18-2004 | 09:32 PM
duunoit's Avatar
Where's the pic? I just got my gauge too. Does it look just like the water temp sender?
Chris
duunoit is offline
Old 04-18-2004 | 09:36 PM
mopower's Avatar
Toxic FORMULA
Mine's in the oil pan . But oil filter location is easier if doing in the boat
mopower is offline
Old 04-18-2004 | 09:38 PM
obnoxus's Avatar
Charter Member #1171
should have 2. one before and one after the cooler.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 04-18-2004 | 10:14 PM
should i just tap it into the oil pan ??
Old 04-19-2004 | 07:02 AM
krypto 1 in CT
there should be a couple pipe plugs on the oil pan rail right next to the lip of the pan i think that should b an ok spot.its where mine is
