Plumbing a  ITS box >
Plumbing a ITS box
Plumbing a ITS box
Old 04-21-2004 | 09:18 PM
seltzer
Default Plumbing a ITS box
Does a ITS box need full hydraulic steering to work, or will it plumb into the brazil valve. There are only two steering lines coming out of the box.
Old 04-22-2004 | 11:05 PM
The ITS needs full hydraulic steering. There isn'a a "tiller arm" to attach the cable/valve/cylinder to. The 2 lines connect to Merc's connector block which includes cross-port relief valves, bleeder fittings, and also has a removable secondary block that the standard Bravo style pump/cooler-return lines can be connected to from the engine.
Falcon is offline
Old 04-23-2004 | 09:41 PM
seltzer
Where can i find a diagram to run the lines?
Old 04-24-2004 | 12:39 AM
It's in the installation manual, I will see if I can find it and send it to you. What type of install? Single, Dual w/single pump, Dual w/twin pump?
Falcon is offline
Old 04-24-2004 | 06:42 PM
seltzer
I have a single engine with no steering, going to ITS with full helm. Thanks for your help
Old 04-24-2004 | 10:02 PM
I have attached a scanned image from the manual of the single installation. The ITS is really the same as other full hydraulic setups except Merc allows the use of the standard pump/cooler connection lines normally used on with the cable system. They also include the bleeder fittings and cross-port relief valves for the R & L lines connections in the connection block.
Falcon is offline
MnFastBoat
6
02-28-2008 03:41 PM
2112
8
05-24-2006 07:28 AM
aquaforce
08-16-2005 12:45 AM
GO4BROKE
Sonic
1
08-11-2002 03:04 AM
onesloryd
1
06-29-2002 10:40 AM
