Dual inlet on water/ fuel separetor >
Old 04-22-2004 | 08:11 AM
Default Dual inlet on water/ fuel separetor
I was going to do the two pickups from the tank into one line for a procharger setup. i bought the stuff to go from two 3/8 pickups into one 1/2 line. then i noticed the other " inlet" on the water separetor and just plumbed each pickup to each inlet, in effect running two 3/8 lines. It seems this would be better. Any one done this? Was it a better idea or am i missing something?
kennyo is offline
Old 04-22-2004 | 01:47 PM
Krumbsnatcher's Avatar
post a pic
Krumbsnatcher is offline
Old 04-22-2004 | 02:15 PM
2 -3/8s would be better. I built a return line(s) in my sending unit cap.You are running a bypass reg?If you are really gonna flow some fuel get a Perma cool sep/filter$32 from Summit and flow 1500 GPH with 1/2 ins and outs(that's mount and filter)
cooltoys61 is offline
Old 04-22-2004 | 02:19 PM
KCHOTBOAT's Avatar
Charter Member #737
Default Re: Dual inlet on water/ fuel separetor
I did the samething to mine with the ProCharger worked fine never had a problem.
KCHOTBOAT is offline
Old 04-22-2004 | 03:14 PM
Official OSO boat whore
I run two 3/8" fittings into the merc fuel filter assembly. BUT-the stock assembly takes 1/4" fittings, not 3/8". I drilled, tapped and ported the entire block. It would be easier to go with one from Permacool.
Cord is offline
Old 04-22-2004 | 03:27 PM
Thanks for the feedback. I've already drilled and tapped the merc to 1/2 ". I guess I did it right.
kennyo is offline
handfulz28
5
11-25-2006 04:00 PM
Vmax
2
07-06-2006 09:01 AM
boatman22
20
02-17-2006 02:23 PM
Raypanic
Fountain
10
10-15-2003 09:44 AM
28SS
2
04-19-2002 03:16 PM
