lifter problem >
lifter problem
lifter problem
Old 04-22-2004 | 03:09 PM
riverboater123
Unhappy lifter problem
Bought a new 454 motor had only dyno time .Took boat out for first time motor was not running good.Removed valve cover,found #8 exhaust valve not moving,found that cam wore though lifter.What would cause this?
Old 04-22-2004 | 03:13 PM
cstraub69@comcast
2 things. Due to the federal government and emissions laws, the sulpher in engine oil additive packages has been removed. Sulpher was a lubricant that helped with flat tappets. Since OEMS now have gone to hyd. roller cams, the Gov. has forced the oil companies to remove this from oil... that is one reason we have experienced so many failures over the last 2 years. The other is we have had 3 major lifter mfg. go out of business or move production over seas. Consequently the product out there has lost the quality it once had, mainly the proper crown on the lifter for rotation. To avoid problem I would suggest going to a hyd. roller.
Chris
Old 04-22-2004 | 07:05 PM
Mr Gadgets's Avatar
Charter Member #601
It could have just not been broken in right.. If they didnt preoil.. and get it to fire right away.. then up to 2500 rpms it can take out a lobe.. do a tear down. or take it back to the builder.. the piston skirts will be full of metal.
Sorry, but thats what happens.. I am using Joe shuebeck liftrs.. big money. but no problems so far..
Good luck
Dick
Mr Gadgets is offline
Bryan Rose
1
06-14-2011 11:11 AM
HighPriority
28
05-29-2008 07:10 PM
Bryan Rose
Prop Talk
3
08-24-2006 09:21 AM
dyno
8
10-19-2004 05:38 AM
Al Oakley
6
09-15-2003 08:28 AM
