Oil To Use? TRIM PUMPS >
Old 04-22-2004 | 03:54 PM
Default Oil To Use? TRIM PUMPS
I know.... Stupid question....
What oil are you using in your alpha trim pumps?
JimmyBaja is offline
Old 04-22-2004 | 04:13 PM
38KV's Avatar
Engine oil, like 10w-30.
38KV is offline
Old 04-22-2004 | 04:49 PM
Official OSO boat whore
Hint-lighter oils are easier on the pump (longer motor life, faster speed)
Cord is offline
Old 04-22-2004 | 05:41 PM
Cord,
Will clear power steering fluid work?
Old 04-23-2004 | 12:12 AM
ttt
Old 04-23-2004 | 08:09 AM
I believe that is what merc supplies. It came in a very small bottle (about the size of the heat bottles for gas) and was very thin. It was clear with a slight amber tint.
Cord is offline
Old 04-23-2004 | 11:59 AM
Originally posted by JimmyBaja
Cord,
Yes, and it works better in colder temps.
Griff is offline
Old 04-23-2004 | 11:44 PM
MERCMAN
i use hydraulic bottle jack fluid if i want it to go really fast. if i need it to go slow i use 10 w 30. plain old engine oil is what is recommended. but the lighter fluids (as in earlier post) work much better!
Old 04-24-2004 | 11:02 AM
epeek's Avatar
How about automatic trans fluid. Any good?
epeek is offline
Old 04-24-2004 | 11:43 AM
MERCMAN
trans fluid works as well. i use trans fluid in the integral trim units. I do notice that it bubbles up easily. they (fluids) all seem to work well you just have to be cautious as to what type of fluid you use. i imagine there are a few that would be bad on the orings in the pumps.
