OT- 98 Chev truck transmission question >
Old 04-27-2004 | 06:01 PM
DanB's Avatar
Charter Member #71
Default OT- 98 Chev truck transmission question
I've got a 98 Chev 1 ton dually w/ 454
Ocasionaly after towing, after I drop the boat, if I drive without towing, the trans will shift real hard, untill the truck is shut off and cools down..then its back to normal.
One trans shop said that 98-99 GM trucks had problems with the engine distributer wearing and screwing up the signal?? to the trans at right around my milage. Since he's turning away business, I tend to belive him. Has anyone else experienced this. The trans has always been serviced regular(just done) and has 90K miles on it.
Does anyone know a message board for Chev trucks info??
Dan
DanB is offline
Old 04-27-2004 | 09:04 PM
blownboat
I have the same tranny and I programmed it to shift firmer. I agree it does shift diff at different times but it doesn't feel bad. There is a temp sensor in the tranny. Maybe it shifts firmer when hot to generate less heat from slippage.Just a thought.
Old 04-27-2004 | 09:18 PM
johnnyboatman's Avatar
low voltage will cause the same symptoms
johnnyboatman is offline
Old 04-29-2004 | 11:49 AM
Its not a bad idea to run a trans temperture guage on a bigger truck pulling a big load. If you see tranny tempertures at or above 260-270 degrees you should install a bigger transmission cooler in line with the factory cooler and consider a deep sump tranny pan. Hot tranny tempertures can cause tranny valves and parts to stick and hang up, which can cause hard shifts when its still to hot.
Raylar
Raylar is offline
Old 05-05-2004 | 07:04 AM
DanB's Avatar
Charter Member #71
Turned out the trans is fine. It was the TPS (throttle position sensor) cause it to shift hard.
Thanks for the input.
Dan
DanB is offline
Old 05-05-2004 | 07:50 AM
These trans control system has a "learning" mode where line pressure is increased under heavy loads or high speed driving in order to minimize slip and reduce heat . Although most drivers probably don't notice it, espesh those that don't pull trailers, it's fairly common.
If there were no other drivability problems, I would be surprised that the TPS was the culprit. I'd be curious to know how it works again under similar driving conditions.
JohnJan is offline
Old 05-10-2004 | 06:39 PM
DanB's Avatar
Charter Member #71
JJ
Ran it this weekend w/wo load...all is well.
Dan
DanB is offline
Rookie
14
10-21-2008 07:24 AM
ratman
0
12-06-2007 01:21 PM
jeff32
10-09-2007 09:48 PM
scarab insanity
07-13-2007 07:45 PM
open wide
4
01-10-2005 11:34 AM
