Metal in Outdrive Oil
I recently had two bearings go out in my Bravo II outdrive. They are the main bearings just behind the U joints. (I am no expert on outdrives I just know what the mechanic showed me when he had it apart) He is replacing the two bearings in the upper part of the drive. The bottom drive still turns fine and sounds ok but I am concerned about the amount of metal filings that the bearings in the bottom foot have been exposed to. The mechanic says it is not necessary to tear apart the bottom and clean the bearings. He said if we just flush it out with oil a few times it will be fine. I am ok with that if it works but I don't want to put it back together and ruin those bearings too. Anyone have any experience with this type of thing?
From: Brussels, Ont. CAN. Landlocked between Lake Huron, Ontario and Erie
zog02- I agree with Jonas and Reed. Have the rest of the drive dissassembled and cleaned, you'll be glad you did. It's not worth the risk to just 'flush n' go'.
My .02
Brian
My .02
Brian
Reed & Jonas & Brain are giving you the best advice you can get. If it really scattered some metal it is even hard to clean the unit once it is apart, we use hot water, detergent and a pressure washer. Must pull all the races as the debris lodges behind them.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
