Hatch Lift Motor
STeve, where do you wire in the relay box? Mine goes up really slow, if it goes up at all.
rough pic how to rig a 4 relay system for motor reversing. (standard automotive relays available at walmart)
At the switch disconnect the DPDT switch and ony use one side (SPDT).
O.K. I'm an electronic idiot I guess. That diagram means very little to me.
Just kidding:
look at the back of your switch, you will have 6 terminals (3 to either side). There will be a wire connecting the upper left to the bottom right and another connecting upper right to lower left. Disconnect these two wires.
Disconnect the ground wire.
Connect the Up wire on the upper side with the hot wire in the center. Connect the down wire to the lower terminal same side.
on the solenoids ground one side of all four coils. connect the up wire to one solenoid coil and bridge to the one next to it. Do the same for the other two solenoids for the down wire.
Connect ground to one of the main terminals on the up side and bridge to one of the down side.
Connect 12v to the remainging solenoid main terminals on the up side and bridge to one of the down side.
All four solenoids should have one main terminal left unused
Connect the motor each of the motor wires as shown on the up side...bridge to the opposite down side.
CLEAR AS MUD.
CLEAR AS MUD.
