Mercruiser 5.0 Electric Ignition Starting Problem >
Old 05-02-2004 | 09:59 PM
Axcel75
Question Mercruiser 5.0 Electric Ignition Starting Problem
I have a 1991 5.0 Mercruiser, 230 Hp, with a 4BBL carb. It has a Thunderbolt Ignition IV. The engine ran fine for maybe 1 or 2 minutes and then died. I checked all the grounds and wiring and it all seems fine. I checked for spark and there was none. I then replaced the ignition sensor inside the distributor cap and the cap itself. I then tried the engine and still nothing. So I replaced the ignition coil. and still nothing. I'm wondering if it is the Ignition Module itself or something else? I was told that perhaps I put in the wrong ignition sensor and that could be causing the problem.
I'm at a loss and I could really use some advise.
Thank you so much,
James
Old 05-03-2004 | 09:36 AM
Did you check the shift interrupt
switch on the shifter cable bracket ?
This, if sticking, will ground the
neg. side of the coil.
Do you have a pos. voltage at the
pos. side of the coil ?
jt
JaayTeee is offline
Old 05-03-2004 | 09:36 PM
220BR
Here is a trouble shooting guide for th TBIV. TB IV Troubleshoot
Old 05-04-2004 | 09:21 PM
Axcel75
Thanx for the trouble shooting guide....I'll check all the components.
James
nkdski
9
01-06-2008 03:32 PM
tontom1989mercv6
06-26-2005 10:48 AM
magnum
0
05-26-2005 07:15 PM
timucin
11-30-2003 05:14 PM
terrygar
3
05-29-2002 10:01 AM
