Any Dodge Tech's? >
Any Dodge Tech's?
Any Dodge Tech's?
Old 05-05-2004 | 06:43 PM
CAP071's Avatar
Question Any Dodge Tech's?
1998 Dodge Ram 1500
When driving down the road, the air bag light will come on and go out. light comes on once in a while, but stays on only about 5 seconds.
CAP071 is offline
Old 05-05-2004 | 06:48 PM
it will need to be hooked up to a scanner to find out why it is coming on most likely nothing serious.
rssteiny is offline
Old 05-05-2004 | 06:57 PM
Ted G's Avatar
Yup, has to be scanned. Likely a loose connector in one of the harnesses, gets open when going over bumps, then resets. There should still be a code stored as to where it is.
www.cbpba.com
Ted G is offline
Old 05-05-2004 | 08:43 PM
epeek's Avatar
When the light comes on,try blowing the horn.If the
horn doesnt work,it most likely is a bad clock spring.
Chrysler has had alot of problems with them. If
that isnt the problem,you will have to go to the
dealer because chry. Air bag info is proprietary, and
isnt supported in aftermarket scanners, such as a
snap-on or Otc. Have to have a DRB to read codes and
info.
epeek is offline
Old 05-05-2004 | 09:09 PM
CAP071's Avatar
CAP071 is offline
salesmanship
Nor-Tech
11
08-24-2008 07:31 AM
Jassman
Nor-Tech
60
05-08-2007 07:08 AM
Perfectmix
Nor-Tech
17
08-04-2006 11:00 AM
Wally
2
11-09-2005 07:26 PM
