Weird cooling prob >
Weird cooling prob
Weird cooling prob
Old 05-06-2004 | 12:01 PM
97BossHammer's Avatar
Default Weird cooling prob
Had a Thermostat go last season...replaced it with another one and now I don't have a good reading on the gauge, it stays below 100 degrees. The gauge is working, if I short it...the gauge pegs out. Got any ideas?
97BossHammer is offline
Old 05-06-2004 | 12:04 PM
offthefront's Avatar
Maybe the Gauge is stuck open ?
offthefront is offline
Old 05-06-2004 | 12:09 PM
I think the gauge is fine it just does not register when the tstat is hooked up. When I touch the gauge wire against metal it pegs it out which tells me the gauge is working.
Old 05-06-2004 | 12:17 PM
It is the sender.You can try taking it out and putting it in hot water to see if it makes the gauge read.But for $8.00 it is not worth all the trouble.
amarket1 is offline
Old 05-06-2004 | 12:41 PM
ah forgot to mention....did that as well, replaced the sender as well as the tstat.
Old 05-06-2004 | 12:57 PM
My bad ... I meant the thermo could be stuck open ...take it out and see what temp does
Old 05-06-2004 | 03:27 PM
mopower's Avatar
Toxic FORMULA
That's my bet . Had that happen to me
mopower is offline
Old 05-06-2004 | 03:56 PM
Did you use the Merc t-stat gasket????
It has crush rivets in it that act as a ground for the sender. Also, you if you use sealant on it or it won't ground properly either.
Griff is offline
Old 05-06-2004 | 04:31 PM
it does have the merc gasket.....I did put sealant on it. guess the next try would be a new gasket w/ no sealant.
Old 05-06-2004 | 06:48 PM
Ted G's Avatar
Got to have the rivets or the gauge won't work.
www.cbpba.com
Ted G is offline
