Noisy lifter... >
Noisy lifter...
Noisy lifter...
Old 05-09-2004 | 12:10 AM
Danny_Ocean
Default Noisy lifter...
454/330
Boat sat all winter and then for another month while I did some mechanical work. Lifters/cam have only a few hours.
Now it sounds like I have a noisy lifter (loud clicking...not an exhaust leak). A mechanic implied the lifter may not be "pumping up" due to sitting for an extended period. Same mechanic suggested adding tranny fluid to the motor oil, running the motor to get the oil pressure up then drain and re-fill.
Thanks in advance,
D. Ocean
Pompano Beach, FLA
Old 05-09-2004 | 04:07 AM
Try adjustuing it. If it only has a few hours on it, then it could have been right on the edge of ticking before and with the first start up, it could have possibly worn just the fraction more.
Griff is online now
Old 05-11-2004 | 12:19 AM
Danny_Ocean
Is there a cold adjustment? I can't remove my valve covers without removing the manifolds/risers...
D. Ocean
Pompano Beach, FLA
Old 05-12-2004 | 12:22 AM
Scratch that anyway. Rereading your post, I'm 99% sure you have a non adjusable valvetrain.
Could be a sticking lifter, not pumping up, and it may just go away. You could try running a quart of tranny fluid in your oil for an hour. It will help unclog/unstick the lifter if that is the case.
How long did you run the engine??? Long enough to heat up to temp???
Griff is online now
Old 05-12-2004 | 08:39 AM
Danny_Ocean
Ran the engine for over an hour at varying rpm's.
D. Ocean
Pompano Beach, FLA
Bryan Rose
1
06-14-2011 11:11 AM
GCAT911
Fountain
1
07-15-2007 10:56 AM
Bryan Rose
Prop Talk
3
08-24-2006 09:21 AM
alorio1
14
07-31-2005 11:28 PM
Tricky919
Fountain
0
06-04-2004 07:19 AM
