new hydraulic steering and boat still wanders @ idle >
Old 05-09-2004 | 06:54 AM
Question new hydraulic steering and boat still wanders @ idle
I just put new dual hydraulic steering on my 28' scarab (single engine) and it still wanders when in gear at an idle. I have checked the drive while the motor is running and there is no slop in the drive at all. what could be causing the back and forth motion? I look forward to your comments!
temp is offline
Old 05-09-2004 | 07:10 AM
Dave M's Avatar
Veteran: Navy
I think that is just a charactoristic of any single engine v-hull no matter what steering system you have. If it only happens at idle I wouldn't be concerned.
Dave M is offline
Old 05-09-2004 | 08:39 AM
Official OSO boat whore
That's the way a single V-bottom is. It has to do with the hull shape. There is nothing wrong with your boat or the steering. Actually, if you can fight the temptation to saw at the wheel the boat will naturally wander in a straight line.
Cord is offline
Old 05-09-2004 | 10:20 AM
Danny_Ocean
Trying to keep my boat straight at low speed is like trying to push a piece of (cooked) spaghetti through a keyhole.
Sounds normal.
D. Ocean
Pompano Beach, FLA
Old 05-09-2004 | 10:40 AM
paradigm shift's Avatar
Yep quite normal. You can try dropping your tabs if you have them. This has is most cases I know eliminated if not at least help the wandering. Sometimes trimming the drive up with the tabs down all the way is the hot ticket. Just something you might try.
paradigm shift is offline
Old 05-09-2004 | 11:40 AM
mopower's Avatar
Toxic FORMULA
Normal , and doubt you'll ever get rid of it
mopower is offline
Old 05-09-2004 | 12:06 PM
If you have not tried using your tabs you really should. It works really well for everyone I know that has tried it. I do not know very many people though.
Old 05-09-2004 | 03:02 PM
KH0302's Avatar
Mine ends up where it was last pointed, though in a zigzag way
KH0302 is offline
Old 05-09-2004 | 09:12 PM
Normal mine does it all the time and I to have hydraulic steering.
nitro/max is offline
Old 05-09-2004 | 10:41 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Go faster.
US1 Fountain is offline
