Regal Velocity Exhaust >
Old 05-11-2004 | 07:08 PM
LA3
Default Regal Velocity Exhaust
I have an 1988 Regal Velocity with 454 Magnum.
The exhaust exits the boat on the left and right rear sides of the boat. Also have huge fiberglass muffler.
What kind of stainless steel exhaust manifolds and pipes will work with this set up. And would I need a switchable muffler.
Please help?
LA
LA3 is offline
Old 05-12-2004 | 09:18 PM
On my 1989 I had lightning headers that connected to a stainless elbow by rubber exhaust hose. Completely removed the mufflers. Sounded loud but good. Picked up about 300 rpms.
Padraig is offline
Old 05-13-2004 | 09:25 AM
I had a 1988 23ft model, 454Mag, put a crane cam with I think 226/234 duration & had some head work done. I then added the Stainless Marine Hi-Torque manifolds and stainless risers. It was a fun boat & fast! I used the existing fiberglass elbows, I think I may have had to modify them (it's been a while), and then I took 1/2'' drill bit with an extension and drilled several holes in the baffillls in the mufflers. It had a nice sound but wasn't too loud!
If I were you, I would go with the Lightning headers with the reduced water flow and install overboard dumps for most of the water. The fiberglass elbows should still be OK, or you could opt for some stainless elbows! You should be able to do the same thing with the mufflers and it shouldn't be too loud!
TomR is offline
1waterboy1
Velocity
20
07-02-2010 09:04 PM
AGGRAVATION28
Velocity
17
10-05-2009 06:13 PM
brian valery
Velocity
4
02-20-2007 03:17 AM
fobes
04-12-2004 05:51 PM
velocitoy
08-30-2002 05:32 PM
