Hi-Tech, anyone... need a 8" piece of Trailer Tongue >
Old 05-12-2004 | 10:20 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Hi-Tech, anyone... need a 8" piece of Trailer Tongue
2" x 3" Box Tube, 8" long or so. Aluminum preferred, but Galvanized Steel is fine too.
Anyone have something they can hook me up with?
Driving from VA thru KY to LOTO next week, can pick up if in path.
I need to move my Trailer Tongue jack, from the actual Tongue of the trailer, back about a foot, over to the I-Beam. I need the piece of box tube to place between the tongue jack mounting plate, and the face of the I-beam to create solid support to move it out past the plane of the flanges of the I-beam.
Attached Thumbnails Hi-Tech, anyone... need a 8" piece of Trailer Tongue-untitled.jpg
Sydwayz is offline
Old 05-12-2004 | 11:17 PM
ToddW's Avatar
Brian call me I have an idea on this.
ToddW is offline
Old 05-13-2004 | 12:02 AM
ChrisK's Avatar
Moderator
ok I will bite....
why?
ChrisK is offline
Old 05-13-2004 | 06:19 AM
Audiofn's Avatar
Charter Member #232
Brian you can try www.championtrailers.com
Put your best foot forward!
Audiofn is offline
Old 05-13-2004 | 06:44 AM
Aggressor 25's Avatar
Brian,
Call Jensen Manufacturing Co. in Alexandria, VA (703) 751-2015. They are on Duke Street. There is a guy there I think his name is Tracy. He made my aluminum wedges for my exhaust with fitting for the pyrometer probe.
Ty
Aggressor 25 is offline
Old 05-13-2004 | 07:35 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
ChrisK, I need to mount my Weight-Distributing Hitch right there.
John, checked Champion, and they won't ship less than 7 feet. Not a big deal, but was just hoping for something easy.
Todd, I will call you in an hour or two.
Ty, thanks. I will check them out.
Sydwayz is offline
Old 05-13-2004 | 07:51 AM
ChrisK's Avatar
Moderator
ahh... makes sense now...
ChrisK is offline
Old 05-13-2004 | 09:20 AM
GregP's Avatar
Will a piece of 4" "C fit over the rails? I have some leftover 4x4x1/8 aluminum box, could easily cut you off and 8" piece.
-Greg
GregP is offline
Old 05-13-2004 | 09:57 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Greg, that may work, but let me look at my options, and see what I can come up with. Thanks.
Sydwayz is offline
Old 05-13-2004 | 11:54 AM
Allan4
Call Brandon at Haskins Hitchin Post in Cincinnati and he will be able to help you out.
Tell him Allan sent you. His number is 513-484-7111
