Water pressure gauge Tap? >
Old 05-15-2004 | 06:45 AM
ofshore's Avatar
Question Water pressure gauge Tap?
I want to put a water pressure gauge in but i'm not sure where to put the tap to measure the pressure so what do you guy think is the best location? My boat has a through hull raw water pump as well as the engine circulating pump. Thanks for any suggestions, Eric.
ofshore is offline
Old 05-15-2004 | 07:02 AM
Airpacker's Avatar
Install a fitting in the block drain hole.
Airpacker is offline
Old 05-15-2004 | 07:06 AM
38KV's Avatar
Or the intake.
38KV is offline
Old 05-15-2004 | 06:55 PM
Default Re: Water pressure gauge Tap?
take airpackers advice
gusman is offline
Old 05-15-2004 | 07:00 PM
mopower's Avatar
Toxic FORMULA
My past three have been on the t-stat housing
mopower is offline
Old 05-15-2004 | 07:30 PM
RLW
Mine was in the block drain hole, when I had an engine.
RLW is offline
Old 05-15-2004 | 07:57 PM
SKRAMER's Avatar
Mine is in the block drain hole also.
SKRAMER is offline
Old 05-15-2004 | 09:00 PM
open wide's Avatar
both of mine are in the drain holes.
open wide is offline
Old 05-15-2004 | 09:32 PM
mopower's Avatar
Toxic FORMULA
ok, ever get clogged with dirt???
mopower is offline
Old 05-15-2004 | 10:29 PM
RLW
Never clogged but have seen a couple pieces of debris in the clear polyflo tubing I used.
RLW is offline
