Can I ?
Old 05-19-2004 | 05:05 PM
Default Can I ?
Since the change with the ability to only sell parts in the classifieds section, can I post a thread here looking for a part? There isn't a section in the classifieds for parts wanted. All I need is a flywheel.
PachangaP22 is offline
Old 05-19-2004 | 05:12 PM
offthefront's Avatar
Default Re: Can I ?
NO NO NO ... you cant ask for a Flywheel ! By the way ...what motor ? Year ?
offthefront is offline
Old 05-19-2004 | 06:41 PM
Default Re: Can I ?
Not sure of the year. It's a Gen 4 454 330hp. Bought a reman with flywheel. Flywheel is rear entry instead of standard front entry. Starter won't reach the teeth.
Old 05-20-2004 | 08:02 AM
Default Re: Can I ?
Looking for casting #3973467N
Old 05-24-2004 | 10:14 PM
DCCollins1
Default Re: Can I ?
Heat up the ring gear with a torch and it will fall off, flip the flywheel around and slip it on the other side (do it fast before the ring gear cools off). Easy fix, I just had to do it with mine.
Old 05-25-2004 | 04:09 PM
aero-offshore's Avatar
Default Re: Can I ?
No, not here Because I would post that I need a good used set of Gaffrig guages.
aero-offshore is offline
