Trailer Hitches
Old 05-22-2004 | 10:18 PM
pair-a-dice's Avatar
Default Trailer Hitches
We are changing our tow vehicle from a pintle hook to a 2 5/8" ball. We were wondering if anyone knows of a ball mount that has a 10-ton rating and fits the 2" receiver on our Ford F-550. We've found a 25,000 lb. ball and our receiver is rated to handle whatever the truck can handle, so all we need is the ball mount so we can make the switch. Any suggestions?
Thanks,
Pair-a-Dice Racing
www.pair-a-dice-racing.com
pair-a-dice is offline
Old 05-22-2004 | 11:38 PM
Chris L's Avatar
Default Re: Trailer Hitches
Call Redneck Trailer Supplies #(813)628-0000 they are in Tampa. They deal in HD type trailering supplies.They list a 12,000 lb in their book for the F-350 Super Duty.
Good luck.
Chris L is offline
Old 05-22-2004 | 11:46 PM
Chris L's Avatar
Sorry about that they list 2 5/16 balls to 40,000lb and mounts to 10,000 the solid ones are not in my old catalog
Chris L is offline
Old 05-23-2004 | 05:36 AM
check out hitchfinders.com
Thunder32 is offline
Old 05-23-2004 | 06:32 AM
GO4BROKE's Avatar
Are you sure of that? The hitch that came with my dually is only a class 4.
[img][/img]
GO4BROKE is offline
Old 05-23-2004 | 08:41 AM
Payton's Avatar
Charter Member #927
Check this out
http://schuckhitches.com/
Attached Thumbnails Trailer Hitches-p5210004.jpg   Trailer Hitches-p5210005.jpg   Trailer Hitches-p5210006.jpg
Payton is offline
Old 05-23-2004 | 10:25 AM
Go4Broke,
Our F-550's hitch is solid welded to the frame, so it will handle whatever the truck can tow.
Thanks,
Pair-A-Dice
Old 05-23-2004 | 11:14 AM
Cattitude's Avatar
Go4Broke,
Thanks,
Pair-A-Dice
Ummm... not to sound like a jerk, and I'm sure you've checked out your hitch for your situation (or at least I hope you have), but a hitch being welded to the frame has nothing to do with it's weight rating. I just don't want someone to read this thread and get the wrong idea.
you even have to be careful with custom work by so called pro's. Just because someone can lay a purty bead does not mean they can properly design a hitch. And most truck frames are designed to have bolt on hitches- welding to truck frames is usully a no-no whether its a dually, medium duty or an OTR truck.
Good luck with your ball quest
Cattitude is offline
Old 05-23-2004 | 11:36 AM
Just to clarify the hitch was installed by Tuscany Conversions and it is welded to the frame but it is also bolted. I am assuming that a quality company like Tuscany knows what they're doing.
Old 05-23-2004 | 12:05 PM
hp500efi's Avatar
Member #9
Did you try them for the ball? Or did they simply do the install? Sometimes the pintle hook is the only other choice besides 5th wheel conversion.
Member of the Liquid Jungle
hp500efi is offline
