Hull Stains
Old 05-24-2004 | 10:45 AM
Stormrider's Avatar
JC Performance Engines
Default Hull Stains
What's up with the dirty water in NY (LI Sound)?
My boat is lifted out of the water all the time.
But just from idling around a bit, my hull has a light brown
stain from the waterline down.
How do I remove it, and is it worth it?
If it only takes an hour for this stain to take hold,
it'll come back all the time. How about any prevention so it
doesn't stick.
Stormrider is offline
Old 05-24-2004 | 11:00 AM
ofshore's Avatar
Default Re: Hull Stains
you could always put bottom paint on it I get the same thing here on lake erie i just use black streak remover spray it on and the stains wipe right off 15 minutes and your done.
ofshore is offline
Old 05-24-2004 | 11:02 AM
Chris288's Avatar
Think the Sound is bad,, try the Hudson River... disgusting...
Chris288 is offline
Old 05-24-2004 | 11:25 AM
spitfire1's Avatar
Thumbs up Re: Hull Stains
Ringo.....hands down the best I have found.....works fast, easy to use.....
spitfire1 is offline
Old 05-24-2004 | 11:26 AM
Rocco's Avatar
Muratic Acid and Hydrochloric Acid are the same
Rocco is offline
Old 05-24-2004 | 11:36 AM
Downtown42's Avatar
Star brite hull cleaner in a spray bottle and a hose. More mild than some others and works well.
Downtown42 is offline
Old 05-24-2004 | 11:50 AM
Dave1972's Avatar
Have used the hull cleaner from West Marine. Is not real bad to use and just wipe on with a sponge and let it sit for 2-3 minutes and spray off. Not sure how to prevent it from happening...perhaps a good coat of wax after the hull cleaner would help at least initially until the wax wears off. I usually do the hull on mine twice per year. Oh yeah, my boat is trailered and not in the water or on a lift.
Dave1972 is offline
Old 05-24-2004 | 12:01 PM
Macklin's Avatar
Ditto! You can get it from Vyper340 who will probably chime in soon.
Macklin is offline
Old 05-24-2004 | 12:12 PM
GLH's Avatar
GLH
"Kaboom" works but once you start you have to do it everytime. Ran into that last year.
GLH is offline
Old 05-24-2004 | 01:51 PM
BillR's Avatar
OSO Moderator
Ditto on the Ringo from Vyper340.
it is the best!
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
