Setting Timing on a HP500 EFI >
Old 05-24-2004 | 01:17 PM
boatinbill's Avatar
Registered User
Default Setting Timing on a HP500 EFI
I am setting the timing on my '99 500 EFI and I do not have a scan tool or a diagnotic code tool.
How do I stabilize the timing so that I can set it with a timing light? (What do I do with the DLC?)
boatinbill is offline
Old 05-25-2004 | 01:39 PM
boatinbill's Avatar
Registered User
Default Re: Setting Timing on a HP500 EFI
Just keeping this at the top, my question is how do I simulate a diagnostic tool being in timing set mode?
Old 05-25-2004 | 01:50 PM
jdnca1's Avatar
You need to jump pins A & B on the DTC connector to put the motor into base timing mode. Start engine and bring to 1500rpm, then set timing to 8 degrees.
jdnca1 is offline
Old 05-25-2004 | 04:42 PM
boatinbill's Avatar
Registered User
Thanks jd, that is what I needed to know.
I knew the 8 degrees, just not how to shut off the ECM from advancing the timing.
awsomethunder
2
06-15-2006 08:08 AM
JeffGrice
2
08-10-2003 09:17 PM
Smitty
1
05-19-2003 07:35 AM
fastedy
05-06-2002 09:09 AM
