Problem with ABS brakes on chevy dually >
Old 05-24-2004 | 11:03 PM
phughes69's Avatar
Default Problem with ABS brakes on chevy dually
I need help trying to figure out what is wrong with my ABS system. The ABS system activates only when I am braking and turning at the same time. I know the wheels are not skidding when this happens. It never does this when I am braking in a straight line. This problem started happening after I put a Detroit Locker in the rear axle. The truck is a 2wd chevy dually. Has this happenes to anyone else? What may be the problem?
phughes69 is offline
Old 05-24-2004 | 11:43 PM
jtmiller02
Default Re: Problem with ABS brakes on chevy dually
Very likely that the locker could be causing rear wheels to turn at a rate different than what the system is set up to "see". In other words without the locker the wheels would turn at a different rate and with the locker they are turning at an equal rate. Not sure how to fix that exactly, but a good 4wd shop should know about this problem as it would be common with these modifications.
Old 05-25-2004 | 05:22 AM
blownincome's Avatar
Lightbulb Re: Problem with ABS brakes on chevy dually
1st what year dually is She..second if she is 1996 or newer she should have a OBD2 computer system and 4 wheelantilock brakes.What you will need to diag this is either a GM tech2 scan tool or I think snapon will work..Go into the software to watch the
wheel speed sensor readings should be a screen with four readings. next monitor all 4 speeds 1 for each wheel sounds like 1 is dropping out before the rest causing your ABS to think a wheel is locking and then activating..she may have a chaffed wire or a partial break in one and it is aggrivated when you turn the wheels..causing a signal interupt..Good Luck
Bob
blownincome is offline
Old 05-25-2004 | 06:32 AM
Audiofn's Avatar
Charter Member #232
I had the same issue with my Ford. It turned out that the rear springs and shocks were smoked and when I was in a turn the tires would hop causing the computer to freek. Since I replaced the shocks and springs I have had no issues.
Jon
Put your best foot forward!
Audiofn is offline
Old 05-25-2004 | 07:46 AM
Blown is probably right, you need to get reprogrammed.
The Locker axles may cause a reading the computer does not recognize.
Also, depends upon the year. Earlier GM's only had ABS on the rear wheels.
Wannabe
wannabe is offline
Old 05-25-2004 | 10:12 PM
fatdaddy's Avatar
I've got a Detroit in my Hummer w/ ABS and no problems. Can't even tell the Detroit is back there except off road.
fatdaddy is offline
Old 05-26-2004 | 01:09 AM
phughes69's Avatar
the truck is a 1996 with 4 wheel ABS
Old 05-26-2004 | 05:36 AM
Look For a broken wheel speed sensor ar chaffed wire.. the wire comes off the hub and has two wires in the shield and has a connector about 12 inches from the sensor . the sensor can be found on the inside of the front hubs (kind of behind the calipers) inspect the connectors and wire/shielding for damage.. that is the visual test otherwise refer to my above info..
Bob J
Chris Sunkin
32
04-04-2007 05:41 PM
oreo11zeus
19
03-28-2007 05:53 PM
open87
7
10-16-2006 06:19 PM
Lmarth
12
01-07-2006 04:22 PM
Mr Gadgets
26
08-18-2002 10:42 PM
