New oil filter study released >
Old 05-25-2004 | 08:05 PM
Grease
Default New oil filter study released
I posted a few months ago regarding oil filters for boats. I have updated the site to include a ton more filters and more data.
www.OilFilterStudy.com
There is a section at the end for Merc boat recommendations.
Old 05-25-2004 | 08:18 PM
Danny_Ocean
Default Re: New oil filter study released
Very interesting read. Guess I better throw away my WIX and go back to Merc.
D. Ocean
Pompano Beach, FLA
Old 05-25-2004 | 09:04 PM
Grease
If you are running the larger 51060, you are probably OK. If you are running the shorter WIX 51086, you may want to try something else.
Old 05-26-2004 | 07:29 AM
Charter Member#350
I have been using Hasting filters for a long time and now I am using Trasko oil filters.
Trasko-usa.com
Zero Cavity is offline
Old 05-26-2004 | 02:07 PM
Airpacker's Avatar
says www.OilFilterStudy.com cannot be found?
Airpacker is offline
Old 05-26-2004 | 02:35 PM
Rookie's Avatar
both links work fine for me.
Rookie is offline
Old 05-26-2004 | 02:59 PM
Budman's Avatar
From: Kentucky - where the women are so fast we have to put a governor on 'em!!
So, is it better to have more flow and less filtering capability, or vice-versa? I would think that flow would be more important in a marine environment, especially when you consider that boats usually don't go as long between oil changes as cars do.
Also, seems like I read on this site in the past that the WIX filters have the synthetic filtering media. It was mentioned that this is better in a marine environment because the non-synthetic media clog up if any water is introduced into the oil. Neither the Wix that was tested OR the Merc have the synthetic media - interesting. Anyone care to comment?
Budman is offline
Old 05-26-2004 | 03:47 PM
Airpacker's Avatar
Can I ask why you didn't include the AC PF932 in your study?
Old 05-26-2004 | 08:24 PM
Grease
I believe the 932 is the 2 quart version of the 1218. I wanted to stay apples and apples as much as possible. Besides, I don't have the room for the 932 in my boat
Old 05-27-2004 | 12:11 PM
Rookie's Avatar
Let me know if I read the study right. It appears to me that the Premium Purolator (not PureOne) has good filtering capabilities, and excellent flow. That seems to be the only one that has both, and would be the best choice?
Rookie is offline
