7.4L MPI in the 24?? >
Old 05-25-2004 | 09:53 PM
Elite Marine's Avatar
Default 7.4L MPI in the 24??
I found a lower time (120 hours) 2002 7.4 MPI motor I'm looking at to possibly install in the 24 to try and sell it w/power.
I know its not a HP motor, but it is turnkey, reliable and should still get the boat moving.
Any ideas of what speeds?
What do you guys thing of this motor in a 24?
Elite Marine is offline
Old 05-26-2004 | 12:13 AM
cuda's Avatar
Default Re: 7.4L MPI in the 24??
A freind of mine ran 59 with the same engine in a 24 Outlaw. You should do better I would think. Ran everytime, just add gas.
cuda is offline
Old 05-26-2004 | 12:58 AM
I race(d) with and maintain Scott B's '00 24SE (GiGi Motorsports), the boat came from the factory with a 7.4MPI. The boat did a realistic 65mph on GPS with two guys and half fuel running realistic trim. Obviously if you run the boat with a lot of trim, running way loose and with less fuel and one guy you'll see a couple more mph!! Hope this helps!?! Jason
JBmarine is offline
Old 05-26-2004 | 07:38 AM
TURBOED's Avatar
what is the hp on that motor?
TURBOED is offline
Old 05-26-2004 | 07:54 AM
I have since gone Bigger but the boat was competative in P5 and we never turned a wrench.
PS If I could find another one cheap, I would buy it for a pleasure motor and use it in the offseason. Reliable, economic, and 65 in a 24 is still fun.
I actually did buy one for a pleasure motor but Dad blew up his and I gave it to him
ScottB is offline
Old 05-26-2004 | 08:36 AM
muffman's Avatar
59 gps with one in a 26 Corsa and 70.4 gps with a 496HO on smooth as glass water.
muffman is offline
Old 05-26-2004 | 12:09 PM
Pat McPherson's Avatar
1989 24' Pantera ran 63mph with a stock 305HP/7.4Carb. spinning a 23p Mirage+.
1997 24' Superboat ran 66mph with a stock 310HP/7.4MPI spinning a 25p Mirage+
Superboat now cracks 70mph with a modified 7.4MPI...
Great low end torque engine.
I too would be interested in a spare.
Hey ScottB, I'm using your old ECU on my 7.4MPI mod.
Patrick
Pat McPherson is offline
Old 05-26-2004 | 09:30 PM
Pat what mods did you do to the 7.4 to pick up that speed?
Old 05-26-2004 | 09:32 PM
I believe the 7.4 MPI is around 310 HP stock. But there are several mods that can be done to get it around 330 HP. I'm interested in what Pat did.
Old 05-26-2004 | 09:38 PM
I also have a 1999 carbed 454 Mag with less than 200 hours available. It has around 365 HP.
Which would you prefer if you were buying the boat? Lower hours or more HP??
