port trim tab not working. >
Old 05-26-2004 | 12:03 PM
JUSTONCE's Avatar
I have a set of dual ram tabs on my boat, and the pump I'm not sure of brand but has the green cover I think its an instatrim pump, prolly from between 1980-1988 The starboard tab runs fine and you can hear the pump run for the port but no motion. Does this setup have a split reservoir for left and right sides. I'm hoping it just needs to be filled?
JUSTONCE is offline
Old 05-26-2004 | 03:51 PM
JUSTONCE's Avatar
Default Re: port trim tab not working.
TTT. I know some of you guys got to be running this pump. I can figure it out myself, but It would really help to have some ideas because my boat is about an hour away from here so I'd like to know what parts/tools to take to fix it so I can get going for this weekend.
JUSTONCE is offline
Old 05-27-2004 | 09:13 AM
JUSTONCE's Avatar
Ttt
JUSTONCE is offline
Old 05-27-2004 | 02:02 PM
Just Once,There is 2 solenoids in the pump 1 for port and 1 for starboard.If you take the pump apart and swap wires and the problem goes to the other sied then you know it is the solenoid.I have them in stock for $39.95 each.Yes it is Insta Trim.If you have any questions please call me at 1-800-769-7698
amarket1 is offline
Old 05-27-2004 | 02:43 PM
JUSTONCE's Avatar
thanks,are those solenoids pretty common? There are no leaks & the motor is operating normally so it would make sense.
JUSTONCE is offline
Old 05-28-2004 | 11:07 AM
They are common but do not leak normally.
amarket1 is offline
Cigret1
13
05-16-2008 02:21 PM
powerquest280
Drives and Lower Units
2
05-13-2007 07:12 PM
35donzi_zf
0
10-24-2004 12:41 PM
Fast Forward
4
05-20-2004 08:23 PM
WHOSNEXT
1
03-13-2004 08:37 PM
