Wet for the first and last time! >
Old 05-27-2004 | 11:16 AM
Formula78's Avatar
Default Wet for the first and last time!
Well, the Formula got wet yesterday after several years off the water. It never really ran right all day (way down on power, intermittant miss). About an hour in it, the motor was just sounding worse and worse. Then my worst fears were realized, it was knocking. The motor is toast. It barely made it back to the dock with a bad knock. Only 2 hours on it. You any of you ever feel like giving up? Maybe the next one should be a rag boat.
Formula78 is offline
Old 05-27-2004 | 11:22 AM
GregP's Avatar
Default Re: Wet for the first and last time!
Been there. Had a crank brake in half second time out on a new motor. Buttoned it up for the year, built another motor, and started again next season. It's a reall bummer, but the years since the boat has been lots of fun and made up for it's rough start.
-Greg
GregP is offline
Old 05-27-2004 | 11:26 AM
BODYSHOT1's Avatar
...hmm...let's see, broken drive shaft w/stringer damage...blown motor..no wait... two blown motors....and oh yeah, the headers are shot too....
..time for a Harley!!
BODYSHOT1 is offline
Old 05-27-2004 | 11:57 AM
dyno's Avatar
Charter Member #655
I quit counting how many times I thought I'd give up....now suck it up and get wrenching you wuss!!! I spent $3500 plus on a rebuild one time and the thing didn't make it 7 miles!!!Bastage wouldn't stand behind it either now I build my own. Just step back take a week or so off and get at it!!!"Rag boat" you sat that again and I'm getting travis and the bat!!!Hows that for a pep talk???
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 05-27-2004 | 12:04 PM
formula31's Avatar
When I blew one of mine to pieces last year, I kept using the boat the rest of the year on one engine, just to stay in the water. I have lots of fingers crossed this year.
formula31 is offline
Old 05-27-2004 | 12:11 PM
JUSTONCE's Avatar
I haven't had 1 full boating summer EVER in my life. an summer is only 4 months here.
JUSTONCE is offline
Old 05-27-2004 | 12:50 PM
Airpacker's Avatar
BTDT....next
Airpacker is offline
Old 05-27-2004 | 01:23 PM
Formula Outlaw's Avatar
Last August in three weeks I lost:
1)propshafts and seals both outdrives
2)blew one of my outdrives
3)lost entire rear axle assembly off triple axle trailer, only two six inch pieces of
springs remaing each side, came off in one piece, never found it and no it wasn't
left at the ramp.
Just under 10K
In water one time with water in carbs so:
replaced stock Merc fuel/water seperator filters with Racorp units which involved
location change to fit.
replaced all trailer wiring and lights with 'LED' units
now replacing exhaust manifolds and risers.
Boat in water once since last August and that was with the water in carb problems.
Hope it's finally squared away in the next two weeks.
It does get discouraging, especially with wife threatening bodily harm.
Formula Outlaw is offline
Old 05-27-2004 | 01:36 PM
Charter Member #319
Makes you wonder why you stay with this hobby.
bajabob38 is offline
Old 05-27-2004 | 01:40 PM
BlownBajaOnHavasu
bummer
i broke two motors back to back as a result of incorrect oil filter/cooler plumbing. fired my motor builder, and built it myself, at which time i discovered the incorrect plumbing. lost two seasons
