New heads, manifolds, risers! lost power in 400 yards! >
Old 05-28-2004 | 06:12 AM
LA3
Thumbs down New heads, manifolds, risers! lost power in 400 yards!
454 magnum. New Merlin heads. New risers. New Manifolds. Put boat in and was running about 4000 rpms. Lost power. Sounded like a miss. Then heard loud rattling noise. Engine would not allow me to go above 500 rpms. And had intermittent "rattle or banging" on port side. Sounded terrible. Looked like there as a white-creamy stuff in top of valve covers. Someone please help.
Boat is a Velocity. Thanks.
LA3 is offline
Old 05-28-2004 | 09:16 AM
dyno's Avatar
Charter Member #655
Default Re: New heads, manifolds, risers! lost power in 400 yards!
Start with the easy stuff and work your way up....electrical first, Timing, wires and cap.
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
dyno's Avatar
Charter Member #655
new cam too????if so did you break it in?????
dyno is offline
Old 05-28-2004 | 09:38 AM
mopower's Avatar
Toxic FORMULA
For starters , that sounds like a load of water. Could be a leaky head gasket or intake by the water passage. With new manifolds and risers it could also be reversion (if they are a different type). In any case the loud rattling DOESN'T sound good
mopower is offline
Old 05-28-2004 | 11:07 AM
aero-offshore's Avatar
I take it you pulled the valve cover ,so not a dropped valve or broken rocker, creamy white stuff is water or moisture, knocking is probably detonation.I would pull the spark plugs from the side that was banging and check those cylinders for water, even run water through the hoses in that manifold to see if the riser gasket is right. Did it smoke out the exhuast, on the side with the banging? if it did, probably head gasket not installed right or not the correct gasket, if the heads are aluminum they need special ones. Dyno's right start with egnition first.
aero-offshore is offline
smokin' gun
Wanted
10
04-04-2008 06:47 PM
scarabrun
Scarab
4
09-18-2007 05:10 PM
288sunny
0
08-13-2007 09:08 PM
davids94
05-25-2005 11:41 AM
davids94
03-21-2005 09:34 PM
