$200/hr
Old 05-31-2004 | 10:56 AM
mcollinstn's Avatar
Default $200/hr
Well, I got my "new" jetski toy wet yesterday. Bought 10 gallons of 118 octane race gas for it and a jug of Maxima 927 oil. With tax and all it came up to right at $100.
I'd say that lasted about 30 minutes of runtime. Computes to $200/hour. Might be well worth it, though.
Gotta do some wrenching on it to get it like I want it. Prop too small. Only GPS's 75.2. Gets there in about 4 seconds though if you can keep it in the water. From 20mph punch it is a REAL eye opener. Kind of hard to get it to 20 from a stop though. Throttle response is incredibly abrupt. A billionth of a mm of throttle movement takes it from 1500rpm to 7000rpm. Can't get it out of the hole without it skyshotting out and porpoising (even if my head is hung over the front cowling). Idles at a nice 1100rpm. Rev chip is 8400rpm. It's on the chip anytime you pull the trigger. Definitely more prop needed. Will have to get one custom hammered cause it has the bigges off the shelf one they (Skat) sell.
Seat cover also kind of abrasive. Chews the meat off my calves.
Good thing there's no sharks in TN, or they'd eat me when this thing spits me off eventually.
fun stuff.
mcollinstn is offline
Old 05-31-2004 | 11:16 AM
Formula Outlaw's Avatar
Default Re: $200/hr
Just what model is this bad boy?
Formula Outlaw is offline
Old 05-31-2004 | 11:19 AM
R Addiction's Avatar
AT Cult Member #3
Default Re: $200/hr
Water Lice!!!
R Addiction is offline
Old 05-31-2004 | 11:56 AM
Reed Jensen's Avatar
Default Re: $200/hr
Water Lice!!!
Lake Lice!..........
Reed Jensen is offline
Old 05-31-2004 | 12:31 PM
Hydrocruiser's Avatar
Default Re: $200/hr
Sounds like it's something made by NASA. What exactly is it?
Hydrocruiser is offline
Old 05-31-2004 | 12:50 PM
mcollinstn's Avatar
Default Re: $200/hr
More like something made by the good Doctor Frankenstein...
I've posted details of this nasty lice monster last fall when I received it in a crate stinking of castor oil and race fuel.
It's basically an assembly of top flight ex-pro mod race hardware from the Team Yamaha shelves that had become obsoleted due to pro class rule changes.
Take an old motor development mule hull..
Take a slightly tired full-on Pro Mod stroker motor (send it to Dan Lamey for a freshening up and might as well throw in a one-off big bore set of slugs)..
Throw in a Skat Magnum 155mm setback pump since the sleeved-down 152mm race pump won't contain this beast..
And sell it on Ebay (yep, I caught wind of this thing on Ebay and bought it "offauction" from the guy - ends up to be everything he said it was).
Takes 114 octane minimum. Three Novi 48mm carb throats suck it down at somewhere around 20 gal/hr when the throttle is in the FUN setting.
Had pix somewhere (should be some on this website somewhere..)
Ah: http://www.offshoreonly.com/forums/s...ad.php?t=61658
Old 05-31-2004 | 01:07 PM
glassdave's Avatar
Neno the mind boggler
Default Re: $200/hr
sounds pretty wild MC. just out of curiosity has anybody broke the 100mph mark on a jet ski. i have heard about some pretty high speeds but dont follow the sport much.
cool pics of your ride on that other thread. would be kinda fun to put it back to bone stock colors and graphics on the outside. helluva sleeper
08 OPA High Points Champion
glassdave is offline
Old 05-31-2004 | 01:39 PM
mcollinstn's Avatar
Default Re: $200/hr
82mph "used" to be the record.
I beileve 88mph is the current record for what we "recognize" as a JetSki/PWC. Some hydroplane went 114 with a PWC motor driving a propellor, but that doesn't count.
There's some guy putting Mazda turbo rotary motors in SeaDoo hulls, but due to pump limitations he's just running in the low 70's.
Another guy is putting a small turbine motor in a PWC (a Polaris hull I believe). Somewhere around a 350-400hp powerplant. I have no idea if it ever has been sorted out yet.
The short amount of time I've spent on mine is eye-opening. I've let 4 others ride it and they've all come back terrified, complete with teeth chattering (in 85 degree air and 80 degree water) and legs shaking - these are guys who are pretty stoic normally but maybe aren't quite as nuts as I...
This little sh!t is not really scary. It behaves pretty predictably at speed - tracks well, hooks and unhoks the pump in chop with no particular drama. And all hung out for a GPS number, I find myself wanting a lot more. Just sounds, smells, and accelerates ina fashion that is not at all NORMAL.
As far as a sleeper, it would be HARD to make it sound stock. Revs instantly through three huge expansion chambers that don't have much water going thru them (think dry pipes). It isn't TOTALLY dry, but it will never sound MILD no matter what you do to it. It also has the entire gauge display panel removed to allow intake air for the motor. You can hear carb butterflies jangling around on their linkages and a big huge sucking vacuum sound when you crack them a bit.
Might could make it LOOK slow, but you ain't fooling many people when it fires up.
Not so much that it is loud, it just sounds VERY serious...
Maybe I'll try to record a clip or something.
Old 05-31-2004 | 08:23 PM
Default Re: $200/hr
Heck, that tractor of yours I saw you doing a wheelie on a month or so back in front of your house gave me the shivers. This macine is amazing. What did you say you do for a living again?
Old 05-31-2004 | 08:53 PM
mcollinstn's Avatar
Default Re: $200/hr
I get paid to run a Tool and Die company, provide operating capital for a motorcycle repair and paint shop and dealership, floorplan a car lot, and dabble in real estate. That list pretty much encompasses the things that provide for me and my family. My livelihood, my career, my job, my work envelope, my professional arena...
The things that make me live are:
my kids,
my wife,
all boats,
fast things that you drive, pilot, or ride (I'm not into fast trains or things you have no direct control over),
things with motors that you can make "do stuff" like dirt bikes or pwc's.
Those are the things that make life worth living. So maybe that makes them things I do for a living...
