Water pressure question >
Old 06-10-2004 | 02:22 PM
toolbox
Default Water pressure question
I have Imco Shorties on a 35' fountain. After the 1st run I had 60 psi of water pressure at wot. I bought the Merc bypass valves and am now running 30psi at wot. As I come in and out of the water it spikes up to 35 psi.
I was told to run around 20 psi at wot. What are you guys running for water pressure at wot? Is 35 psi to much? I don't want to start lifting head gaskets.
Thanks in advance
T.J.
Old 06-11-2004 | 06:34 AM
RLW
Default Re: Water pressure question
Try a Globe Blue Impeller from www.Boatfix.com
It is of a softer more plyable material than stock. I ran one and never exceeded 25 psig at WOT. 7-8 psig at idle. This was on a Supercharged motor with crossover that has bypass. Before the Globe Blue, I had water pressure issues.
I am going to run the same setup on my new N/A 540. It is a good starting point. I will post results.
Attached Thumbnails Water pressure question-impeller1.jpg   Water pressure question-impeller2.jpg
RLW is offline
Old 06-11-2004 | 08:58 AM
Tonto's Avatar
RLW,
Do you find that the blue impellers last longer than the black rubber ones? I would like to put these in the SeaRay and want something that will last. Thanks for posting the website for them.
Robert
Tonto is offline
Old 06-11-2004 | 09:28 AM
toolbox
Thanks for the input.
Old 06-11-2004 | 09:35 AM
R Addiction's Avatar
AT Cult Member #3
Stock 502 Mag MPI. 15-20 PSI WOT. 7-8 PSI Idle. Your pressure seems awful high!
R Addiction is offline
Old 06-11-2004 | 11:27 AM
toolbox
Do you have a p/n for that impeller? I can't find it on the web site.
Old 06-11-2004 | 11:59 AM
RLW
For the Globe Blue GRW2000 impeller, call Les Hall at BoatFix at
561-848-0193.
He could steer you in the right direction.
Good Luck!
Russ
RLW is offline
Old 06-11-2004 | 12:06 PM
aTX427's Avatar
I used a -10 pop off valve to keep the pressure at 18 at WOT. You can plumb it into the main water supply between the the oil cooler and the cross over. I never had any problems with temperature or head gaskets.
aTX427 is offline
Old 06-11-2004 | 12:20 PM
I am running a pair of HP500's with Bravo I's at idle I have 1 to 2 psi and at WOT I am in the 15psi range. Am I out of spec? I never have heating problems. Extended idle it is in the 150 range, and at WOT maybe in the 165 range.
Go Big is offline
Old 06-11-2004 | 06:01 PM
RLW
Go Big,
When was the last time you looked at your impellers?
Those numbers seem low to me.
Russ
RLW is offline
