boat wont track straight >
Old 06-10-2004 | 06:19 PM
airshares's Avatar
Default boat wont track straight
I am new to boating and I have a 1997 Scarab 23. When Im going 5 mph the boat drifts left then right left then right etc, etc.......it wont just track straight. it just wanders back and fourth until eventually i have to correct it. Its getting kind of annoying. I cant find any free play in the drive and I know my steering ring was just replaced so its tight but I do have free play at the steering wheel. If that could be the problem is there a way to tighten it up? The boat is fine at any speed above 5 mph but when im trying to get in and out of my harbor its a long time of wagging back and forth.
airshares is offline
Old 06-10-2004 | 06:42 PM
Elite Marine's Avatar
Default Re: boat wont track straight
Welcome to boating!!!
Elite Marine is offline
Old 06-10-2004 | 06:45 PM
fund razor's Avatar
single I/O, deep V, low speed= wander. Have a boat that does it too. There's a zen kind of feel you will get, and you will make it straighter, but it's the nature of the beast. It's worse with a bad skeg. Or with the drive up.
I highly doubt that your boat is broke.
You really will get better at it. Look farther ahead and don't correct so much.
Keep watching that snake behind you, it will get better.
fund razor is offline
Old 06-10-2004 | 06:48 PM
fund razor's Avatar
Oh, and also... welcome to boating.
I hope you are mechanically inclined, rich, and very patient.
Good sense of humor helps too. Epsecially when it's your fault.
P.S. Don't yell at people. Especially the ones you sleep with. It won't help anyway, and everybody will think you are a jerk.
Bam. There's all I learned in 25 years of boating. (plus I can McGiver anything)
Old 06-10-2004 | 07:05 PM
Smitty's Avatar
If you have trim tabs, drop them all the way down and it will lessen this happening. It is really just acharacteristic of the setup as others mentioned.
Smitty is offline
Old 06-10-2004 | 07:15 PM
Keith's Avatar
CBPBA's Walmart Greeter
This is normal in my experience. Wind, wave action and current will affect track & path at that speed.
K2
CHESAPEAKE BAY POWER BOAT ASSOCIATION
'http://www.cbpba.com'
"Experience is something you don't have until just after you need it."
Keith is offline
Old 06-10-2004 | 07:32 PM
Mr Gadgets's Avatar
Charter Member #601
You could trade up to a bigger boat with twins?? Not sure, I have not done that. Check to see if the fin above the prop is straight.. but like all singles, you will get used to the wander, just dont over correct and it will bother you less and lesss..
I have a couple of bridges for sale in your area.. that would take your mind off it..
like those guys said... welcome to boating, it only gets better from here..
Good luck
Dick
Mr Gadgets is offline
Old 06-11-2004 | 07:13 AM
on my 22 Scarab I got used to steering before it wagged,,kinda beat it to the punch by anticipating because if you wait til it goes left to steer right,,it's too late. Now I'm trying to get used to 4 levers and keep throwing it in "idle" for reverse or leaving it in gear to long,etc. Enjoy your 23 they are beauties.
cooltoys61 is offline
Old 06-11-2004 | 08:25 AM
CFD12's Avatar
That is pretty typical of a stock bravo/alpha setup. All of my boats have done this. Try this ( if you have room) Don't touch the wheel. I used to try and correct every movement but it is impossible. If you let it do it's thing it will keep a pretty good course with only minor corrections needed.
CFD12 is offline
Old 06-11-2004 | 08:42 AM
robyw1's Avatar
This is what works on my 22' Scarab. Also I noticed that if you bump up the trim a little it helps too.
Roby
robyw1 is offline
