Transmission fluid what are you using?????
What kind of fluid are you using in your trans????? I have had a problem with one of my trans and a builder is telling me to run 5w 30 in it to keep the clutches hooked up as to it will add pressure.
what kind of trans ya got in there cupcake . . . .
08 OPA High Points Champion
Old school type F in my Merc II trans. I've heard that anything with dextron may cause it to fail. I don't know if that's true, but the F seems to work fine.
I have B&M Trick Shift in mine (merc Trans). They shift better then with standard fluid and also seem to run cooler (checked with IR gun)
Jon
Jon
Put your best foot forward!
