Gauge Bulb Reference >
Old 06-15-2004 | 08:07 PM
Default Gauge Bulb Reference
There was a post on here at one time asking about replacement bulbs for the "red" lights in the gauge cluster of older Formulas that didn't manage to go anywhere. Has anyone got a part number or whatnot for these bulbs? My gauges are getting a little dim. 1989 311 sr-1. Thanks.
SeaWeasel is offline
Old 06-15-2004 | 08:59 PM
Ted G's Avatar
Default Re: Gauge Bulb Reference
Check Pep Boys, Auto Zone, etc. they have them in all kinds of colors including red.
www.cbpba.com
Ted G is offline
Old 06-15-2004 | 10:05 PM
offthefront's Avatar
I checked with AutoZone ....they had no clue ...I found some on the web ...when I find it will post the site ...
here ........
http://www.egauges.com/vdo_agrp.asp?..._Bulbs_Sockets
offthefront is offline
Old 06-16-2004 | 11:26 AM
Mine are pretty dim also ('89 311). Just figured thats the way they were. Will new bulbs brighten them up?
ThirdBird is offline
Old 06-20-2004 | 07:18 AM
Dave ....get your truck goin ?
Old 06-21-2004 | 05:58 AM
Well Mike,
After $600 bucks worth of new tires and $100 bucks worth of alignment and no less than seven different balance evolutions at two different shops, the friggin' thing still vibrates at highway speed. We think it may have a run-out problem with one of the rear axle shafts. It is totally frustrating trying to fix vibration problems.
Did you make the trailer deal, hope all went well.
Old 06-21-2004 | 06:36 AM
Yea.....got it done ...thanks for being a good guy about it all ..... I'll keep a look out for ya ....
we need to get this bulb issue resolved ..I cant stand these dim Gauges
Old 06-21-2004 | 07:20 AM
I put 10 new bulbs in yesterday . . . and should know next weekend whether I got anywhere. I believe the retail on the VDO bulbs is like $6.00 each . . . so, let me be the idiot guinea pig before anyone else blow the money. And, according to Glencove Marine, LOTO, you can't get the particular VDO gauges used in this vintage 311 anymore and they (being VDO) only used this bulb in that series of gauges. Sweet.
Old 06-21-2004 | 08:07 AM
That figures,,,,, I just love owning one-off stuff
Old 06-30-2004 | 08:33 AM
mcollinstn's Avatar
You might could use LEDs.
Get a superbright red LED. Take 320 paper and scuff the outer surface (cause otherwise they are designed to "shoot" the light out the end like a lens). You'll need to run a resistor on each one, unless you chain 4 of em in series (they like around 2.3 volts, and will only work "one direction" with negative to the short lead I believe). LEDs last forever. I've been using them to replace things like the backlighting in my hot tub panel, and other stuff like that..
mcollinstn is offline
