Bravo Gear oil leak at Gimble >
Old 06-17-2004 | 12:01 AM
HiPerf2000's Avatar
Default Bravo Gear oil leak at Gimble
Boat has been on the rack for 4 days, and when i went to the marina tonight i saw some Gear oil under the one drive. I traced it up the drive and into the Gimble. I guess it must be leaking where the resivour hose goes throught the gimble.
How does the hose connect here? is there a fitting with an end on each side, or is this one continuous hose??
How do i get at it to fix it ?
HiPerf2000 is offline
Old 06-17-2004 | 12:10 AM
Default Re: Bravo Gear oil leak at Gimble
The plastic fitting that goes through the transom can crack. You need to remove the the hose inside by pushing the release on the 90deg hose fitting. Then remove the e-clip holding the thru-hull fitting (be careful not to lose it, or have another one handy). With the drive trimmed up and steered to port you may be able to push the fitting through. The replacement part should only have 2 barbs instead of 3. The fitting would crack at the thin area of the 3rd barb. Good luck!
Falcon is offline
Old 06-17-2004 | 07:21 AM
HiPerf2000's Avatar
Thanks Falcon, i'll look for that tonight.
Does anyone have a part number, or link to an online schematic that i can look at ?
Old 06-17-2004 | 02:12 PM
HiPerf2000's Avatar
anyone have part numbers or any other ideas?
Old 06-17-2004 | 02:19 PM
rchevelle71's Avatar
Mark,
I posted the parts diagrams, you know where.
rchevelle71 is offline
TROUBLE MAKER
Drives and Lower Units
26
07-04-2020 02:04 PM
mez
2
04-28-2007 10:45 PM
Dock Rat
12
05-11-2005 09:56 PM
RUSSSR1
12
03-17-2004 08:32 AM
Ran-Dom 32
4
07-08-2003 09:26 AM
