Water Pressure gauge hookup on closed cooling engines >
Old 06-18-2004 | 01:15 PM
Default Water Pressure gauge hookup on closed cooling engines
OK, I know where to hook up a water pressure gauge on a standard engine...usually at the block drain or some like the intake. But...where do you hook up the gauge on a closed cooled engine such as the 525EFI and 496 engines? Hooking a pressure gauge up to the same location will not tell you if you have a water restriction or pressure prob. because the raw water will not be read by the gauge. So is it best to hook it up right after the sea-strainer? or after the raw water pump? Where did boat builders install on these engine setups? Thanks for the help.
Chase910 is offline
Old 06-18-2004 | 01:55 PM
mopower's Avatar
Toxic FORMULA
Default Re: Water Pressure gauge hookup on closed cooling engines
I would definitely go AFTER the seawater pump. If the impeller goes south you want to be able to see it. Before the seawater pump would only show a restriction like a plastic bag on your drive .
mopower is offline
Old 06-18-2004 | 02:26 PM
Mbam's Avatar
Offshoreonly Advertiser
I had mine right before the exhaust
Mbam is offline
Old 06-18-2004 | 03:30 PM
Put your pressure gage at the output of the seawater pump. After all, pump output is what you want to monitor. Differences here will alert you to a bad impeller, intake restriction, or even a blockage in the heat exchanger. There's not really any other place to put it.
Liberator21 is offline
Old 06-18-2004 | 04:23 PM
On the 525 there is a pressure sender on the top starboard side of the oil cooler on the back of the motor. We take this sender out and install a tee in the cooler with the sender on top and the gauge to the side. This will show you the same pressure the computer see's and is before the water passes through the coolers.
Steve Schmidt
Competitive Edge Marine
Steve Schmidt is offline
Old 06-18-2004 | 08:25 PM
Ahhhh, Yes, thanks Steve and everyone else! I definitely want to keep track of the raw water impeller.
Chase910 is offline
sandcraft
10
04-05-2006 09:44 PM
Sammy
4
12-29-2004 09:29 PM
paulr
4
02-01-2004 08:38 PM
Nordicflame
6
07-23-2002 10:08 PM
C_Spray
7
06-17-2002 10:07 PM
