Good Prop for 24'
I am selling a 3 blade hydromotive 24" in the parts swap section. This prop worked very well on my 24' when I had 400 hp, RPM's are too high now with 500hp so I use a 26" pitch prop. It is a very neutral running prop(it does not lift the transom like the 4 blades) and a great all-around prop for this hull. It is 15.5 in diameter and slip numbers were about 7 to 8 percent at wot. Thanks, Chris
