cleaning corroded terminals >
Old 06-20-2004 | 09:20 AM
aTX427's Avatar
Default cleaning corroded terminals
I heard that I can clean up minor corrosion from underneath the dash by soaking the guage terminals, and distribution blocks with WD-40 and letting it sit for a couple of days. Has anyone tried this or know of a better way?
aTX427 is offline
Old 06-20-2004 | 03:43 PM
micky dee
Default Re: cleaning corroded terminals
i would use electric contact cleaner. followed by dielectric grease on the contacts. or daping liquid plastic on the contacts
Old 06-20-2004 | 10:30 PM
mcollinstn's Avatar
'pends on what type of corrosion...
Green crap on brass? Start with a penetrant (WD40, CRC, etc) and disassemble.
Then take a wire brush and clean each disassembled component individually.
When reassembling, dab waterproof grease on the terminals, assemble them, then spray them with a protective covering (cosmolene, battery terminal protectant, liquid vinyl).
mcollinstn is offline
Old 06-21-2004 | 06:21 PM
aTX427's Avatar
Yes - just light green crap on terminals. Is taking the terminals apart necessary? The boat will only be run in fresh water for now on.
aTX427 is offline
Old 06-21-2004 | 06:51 PM
cuda's Avatar
I have the same problem with one of my boats. I'm just going to replace the whole fuse panel. Anyone know where to buy them? I think there were 18 fuses in the panel.
cuda is offline
techman
Fountain
1
07-07-2008 06:48 PM
C_Spray
02-19-2008 03:01 PM
NASTY HABIT
14
08-21-2002 10:21 PM
kook
23
06-26-2002 07:58 PM
Rich36PC
15
05-06-2002 08:16 PM
