???? about warning beeper on 496ho >
Old 06-21-2004 | 05:51 PM
Default ???? about warning beeper on 496ho
Just had a new water pump installed, first time out warning beeper went off. Engine temp was fine, outdrive fluid resevoir looked low. added about 4 ounces went back out, same thing. Question is when that warning beeper goes off, does it limit the amount of fuel to the motor? It seemed like someone hit the brakes when the alarm went to a steady tone. Any help would be appreciated. I am brand new to the sport.
[email protected]
jcimprover is offline
Old 06-21-2004 | 07:12 PM
Default Re: ???? about warning beeper on 496ho
When the beep goes steady the engine goes into safe mode. It will limit power to protect the engine.
You may have a problem that many of us have had when changing the pumps. Try this: when you start the cold engine, wait until oil pressure builds and then rev to 1500-1800 RPM until you hear an audible difference in exhaust tone (you can also just check for water flow). If that does not establish a good flow or you continue to have the problem you may have to have it checked by a pro.
Good luck,
Dave
Vyper340 is offline
Old 06-21-2004 | 07:47 PM
Water pump has a pressure sensor, be sure it is connected after the replacement.
Island Hopper is offline
chuckbeecher
Active Thunder
48
04-16-2007 09:27 PM
Dave M
28
10-20-2005 12:05 PM
JJONES
7
08-19-2004 09:23 PM
wild willy
04-27-2002 12:37 PM
