525 Back Fire Threw Carb
Has Any Body Run Accross Backfiring Threw Carb Around 3k?wide Open Engine Runs Good And Idle But 3k aint So!sometimes It Sound Like A AUTOMATIC 9MM Gun,pop Pop Pop.drained The Tank Thinking It Was Bad Fuel But The Other Motor Runs Fine!some Help Would Be Real Great!
Is it while under a load getting on plane?
A friend had the same problem on his 540's It was bad valves
Do a compression test.
His motor ran fine after he got it up on plane
Mark
Mark
Mark
Mark
Check the plug wires for crossfire first before you pull the heads off. Also verify that the plug wires are correctly routed. Don't think the worst until you look at the simple things. Take it from someone who removed the starter from his boat only to find it wouldn't start because it was slightly in gear.
Roby
Roby
It seems to only happen when hitting a wave!plugs look good!went to havasu for a week and it never happened,only on the ocean!only happens around 3000rpm!Motors only have 100 hrs on them.The boat did have the problem when I bought it with 50 hrs.The boat sat for 3 years before I bought it!
Have you changed your water seperators. If the boat sat for 3 years could be alot of condensation built up in the fuel tanks and then being caught in the seperators and starving the motors for fuel at certain times. just a thought
I Did Change The Water Seperators Twice And It Does Seem To Get Better But Have Run Boat 50hrs.im Going To Change It Again And Keep My Fingres Crossed! Thanks For The Help
Re: 525 Back Fire Threw Carb
Everyone has good idea's of what to check. You may also want to check float level and check for wires rubbing on the edges of brackets and loose wire connections. All these things will give this type of problem. Have seen where wiring coming out of the harness bends around a bracket and are chafed.
If you need any other questions answered or a direction to go in feel free to call the shop.
Pwrbt33- John S.
Offshore Performance
410-827-0200
1-877-GOFAST1
Pwrbt33- John S.
410-827-0200
1-877-GOFAST1
