HELP! truck tires
im at my wits end.
last week i bought new Hankook Dynamic Radials 245/75R16E for the truck (dodge 2500 4 x 4 clubcab) and i barely got the boat home towing with them. very squishy. i was all over the road.
so , today i took them back and had Bridgestone Dueler A/T Revos put on.
a little better but not much. still dangerous.
i had extremely old worn out dry rotted Firestone Steeltex on it before and it towed great. no squishyness at all.
ive tryed different tire pressure up to 80 psi (the max) which seams to be the best but its still dangerous.
anyone have any ideas on what i should try next?
ive probably only bought new tires twice in my life. never keep a vehicle long enough to warrent them.
You might consider Perelli(sp) truck tires. Talked with a driver years ago at the fuel pumps, and he complained of the same problem, and corrected it with Perelli's
But, I'm surprised of your problem with Revo's. They're a great tire. Hope you get it sorted out.
10 Ply E Load Rated in one of 2 brands ONLY:
BF Goodrich All Terrain KO
Cooper Discoverer AT
I have had them both, and both are FANTASTIC truck tires. I won't tow with anything else.
Send a PM to Mama Tryed here on OSO. He will hook you up!
More than likely , those Firestone Steeltex Tires, were the O.E. Tire on your Truck, either a A.T. or the R4S.. Great Tires!! The Revo's that you have now, are One of the Newest Designed Tires on the Market. I have sold several, but I have never Run them Personally.
My advice to you, if you aren't going to keep the Revos, is use a Tire that is the Least Aggressive as you can get by with and use a 10ply.
It seems like the Michelin All Terrain is everybody's favorite,, Great Tire for sure,, I run the LTX M/S on my F350 Rear and the XPS Rib on the Front. The Michelin XPS Series have all Steel Casings. Great for Towing. I would have used them all the way around the Truck, except for the Ramps at Lake Cumberland are at a 90 degree angle and I didn't know if the Ribs would have enough Traction to pull me Out of the Water or not.
Could you not Find the Firestones, or were just wanting to try something different?
i tryed to get by cheap at first with the hankooks but learned my lesson so i went with what i was told was the best with the revos. both are e rated 10 ply tires. i dont want to be a peta with the tire place but i need something else so i guess ill have them put on a set of firestones. if that doesnt work should i try a 14 ply tire? im really baffled that the old tires didnt wallow like these news ones.
