496 HO Audio Alarm System >
Old 06-22-2004 | 10:18 PM
dropthehammer
Default 496 HO Audio Alarm System
Boat was running great all weekend and then I get this invasive alarm while running at cruising speed. It was two long beeps followed by about 40 seconds apart. Water temp was fine, oil temp was fine, and no visual lack of fluids - of course the alarm stopped when I put her in neutral.
One concern was the lower unit oil so I topped her up and the alarm seemed to have stopped. However, the fill line here is unclear and ironically enough, when the boat was idling I sat in the side (boat leaned) and the alarm sounded. When I got off, it stopped. Thus, my laymen's approach tells me it is more than likely a fluid somehwere. Any ideas? Is there a 'shortcut' document that relates these audio alarms to actual problems? Any insight is appreciated...
Old 06-22-2004 | 10:56 PM
Default Re: 496 HO Audio Alarm System
Sounds like the outdrive fluid reservoir bottle alarm... I tried to flush the muck out of the bottom of the bottle this past weekend after my alarm went off as well...
The fill line on my bottle is about 2/3rds up from the bottom.
L8Shift is offline
Old 06-23-2004 | 07:48 AM
dropthehammer
TTT...I think it is the outdrive fluid as well. Any other thoughts?
Noise Pollution
6
03-26-2008 08:30 AM
schill
Beware and Stolen
1
11-23-2006 12:12 PM
Sydwayz
Active Thunder
8
05-24-2006 09:13 AM
tmthunder
4
09-12-2004 08:33 PM
zokman
4
05-27-2003 07:44 AM
