trim pump question? >
trim pump question?
trim pump question?
Old 06-23-2004 | 11:43 AM
Default trim pump question?
I bought a set of used set of k-plane style trim tabs, but they did not come with pumps. can I use outdrive trim pumps? Are the pressures different? If they are, can they be changed? Is the valving adjustable, or a changeable carriage?
218diver is offline
Old 06-23-2004 | 11:50 AM
Shooter's Avatar
Charter Member #300
Default Re: trim pump question?
I just did the same thing. Make sure you get the "newer" trim pumps, they are low pressure vs. the older units which might blow out your seals. There is a high-pressure (grey) and low-pressure (black) hose. I got two of these with all solenoids, wiring, and mount for $125.00 each. Let me know if you need the info.
I simply had ss brakelines which are much cheaper than the stock hoses. Make sure you use tapered pipe fittings and get adapters to AN style fittings. Like I said, I just did this and have parts info if you need.
Later.
Shooter is offline
nocigarette
2
03-30-2006 08:30 PM
jvschlegel
02-13-2006 07:31 PM
ratman
01-26-2006 07:48 PM
later
6
07-01-2003 08:31 AM
Hot Boat
1
05-30-2002 10:19 PM
