Looking for Bravo Template.....help..anyone? >
Old 06-28-2004 | 02:01 PM
Wally's Avatar
Were doomed!
Default Looking for Bravo Template.....help..anyone?
I need to get a hold of the bravo Template specs. If anyone has a drawng they can email me or all the specs that would be awesome! I need to drill two extra holes in my transom for a Alpha/Bravo conversion and i dont want to "eyeball it"
[email protected]
-Wally
Wally is offline
Old 06-30-2004 | 10:54 AM
Default Re: Looking for Bravo Template.....help..anyone?
if im correct ther should be a gasket between the hull and drive ....run to you local merc drive shop and order a gasket
EvoB is offline
Old 06-30-2004 | 03:39 PM
Zanie's Avatar
Nope, you are not correct! Bravo has a big o-ring lookin' seal.
TRS has a big gasket, but a gasket doesn't give you the engine centerline anyway.
C'mon somebody has to have this sheet of paper sitting in the bottom drawer of their toolbox, right?
Zanie is offline
Old 06-30-2004 | 03:46 PM
dlbCheckmate's Avatar
When I did mine, we used screw in locators in the stud holes, you could make some if you don't have them. Just grind a point on the end of a short stud and screw it into the new hole locations as far as you can. Then slide the unit into the existing holes and leave a mark. Easy as pie.
dlbCheckmate is offline
Old 06-30-2004 | 04:23 PM
Official OSO boat whore
That's what I was thinking. Keep the existing 6 studs and sharpen some headless bolts for the other two. Then just jamb it on. You don't even need to use the center punch!
Cord is offline
Old 07-02-2004 | 06:54 AM
Pwrbt33's Avatar
I have one of these in my tool box if you still need it. Give me a call at the shop.
Pwrbt33- John S.
Offshore Performance
1-877-GOFAST1
410-827-0200
Pwrbt33 is offline
littledcsrodshop
05-12-2008 10:35 AM
littledcsrodshop
Drives and Lower Units
4
05-01-2008 02:50 PM
Prater
7
01-06-2005 06:07 PM
rws
1
10-07-2002 11:00 AM
