any 1 with a 29' fountain with a 575 >
Old 06-29-2004 | 06:41 PM
Question any 1 with a 29' fountain with a 575
looking for some help with top speed ..... running low 80's with tabs up wondering if dropping tabs down will help or hurt top speed
4CLOZIN is offline
Old 06-29-2004 | 07:29 PM
BAJA WILL's Avatar
Registered User
Default Re: any 1 with a 29' fountain with a 575
4Clozin
Dropping your tabs should actually slow your boat down, they will create more drag. Only exception to this would be if you are chine walking at all (bouncing side to side @WOT) however I usually don't hear a 29 doing that more of a 27 issue.
What rpm and prop are you running?? also what gps speed are you getting? Also what year is your boat? The knowledge of this board is geat, the more details you can give us the better advise we can give back.
Oh yea try tracking down your test sheet from Fountain, that should have your WOT settings and speed the day she came out the door.
Will
BAJA WILL is offline
Old 06-29-2004 | 11:49 PM
Mark D's Avatar
I think they recommend at least a 2 on the tab.
That should be even with the hull & give a more stable planing surface.
Mark D is offline
Old 06-30-2004 | 12:12 PM
my boat is a 2003 with the tabs all the way up i get 5300rpms running a 28 prop gps says 83-84 but trim down to 2 in 1-2 chop boat seems to run faster wondering if this is something anyone else has experinced trying to get the most out of the boat stock so i can decide on mods or not
4CLOZIN is offline
Old 06-30-2004 | 02:11 PM
Running a 1997 29 Single with a blown 509, usually run the tabs at 2 - 3 and run 88 - 89.
Fountaineer is offline
Old 07-22-2004 | 09:05 PM
carney's Avatar
A friend of mine has a 2000 29 with a 575 sci and he changed the blower pully and a 30 bravo. I think he has said the boat in rough water will run 86 on gps.
carney is offline
FountainMike
Prop Talk
36
02-08-2008 08:59 AM
skopi55
Fountain
15
04-04-2007 07:49 PM
Boomer35
General Racing Discussion
1
02-05-2007 12:24 PM
cwhite
16
08-17-2006 08:10 AM
Cam-shaft
12-18-2005 12:13 PM
