Fuel Pump Housing Oil >
Old 07-01-2004 | 07:31 PM
Default Fuel Pump Housing Oil
I'm running a 500 hp and I'm replacing the fuel pump cam and shaft body which the pump bolts to. There is a oil reservoir which the cam and fuel pump arm lives in. What type of oil does Mercury recommend to run in there. A gear lube or a engine oil plus what W ?????
Thanks.
Active Mike is offline
Old 07-01-2004 | 08:17 PM
maverick1
Default Re: Fuel Pump Housing Oil
I'm told the good lower unit lube is what they put in there.
MAV
I can check the manual if you are concerned.
Old 07-01-2004 | 09:11 PM
Maverick,
If you have the manual I would appreciate it.
Thanks.
Old 07-02-2004 | 08:19 AM
maverick1
I'll check. The manual is at home.
I'll let you know -- probably tuesday.
MAV
Old 07-02-2004 | 10:50 AM
Doller Offshore
hi performance gear lube,
Old 07-02-2004 | 09:56 PM
Thanks guy's for the info.
Have a good 4th.
Old 07-03-2004 | 07:11 AM
I had both pumps replaced at 300 hours. One started to leak a small amount of fuel into the oil.
My mechanic switched the Merc Syn OD Oil with Amsoil Gear Lube.
Jeff
JeffGrice is offline
Old 07-03-2004 | 10:13 AM
I would stay with the Merc hi pro grea lube as if there is a small water leak from the water pump the merc is suposed to hold it.with anything else it will go to the bottom and shoot the bearings.Drain into a cup check for water and refill every season.
FloridianSon is offline
alecsammy
0
09-21-2008 09:47 AM
klaw
5
06-05-2007 08:49 AM
Thunderstruck
0
07-25-2006 01:10 AM
BeakBoater35
4
08-29-2005 08:33 AM
Nordicflame
4
03-04-2004 10:21 AM
