How much deadrise?
Trying to figure out how much deadrise my 1986 F3LS has...As a second question how does more/less deadrise effect speed and handling? I assume that the deadrise would be the same as an 86 242LS but Im not sure. I would like to find out for sure...
Randy
"Bad-Habit"
Randy
"Bad-Habit"
I could have sworn I saw the deadrise of the boats listed on the Formula site in the vintage area, but I just looked, and it wasn't there. The boat is 21'6" and weighs 3500 pounds.
Originally Posted by cuda
The 242 is a 24 degree deadrise. Less deadrise will usually give you a higher speed, but at a cost of pounding.
BH
Originally Posted by BAD-HABIT
How would a 24* deadrise compare with Baja's,Checkmates,Fountians,Donzi's etc....
BH
BH
I think the 26 Donzi Zx is 23 degrees. I think this measurement may be a little deceiving. It is measure at the transom, but will gradually flatten out along the bottom. I don't think it is the end all in figuring how a boat will ride, but it may be the only hard figure to look at that can be compared from boat to boat.
