Dyno Needs A Balancer >
Old 07-07-2004 | 09:08 PM
MitchStellin's Avatar
Default Dyno Needs A Balancer
Don needs a balancer for his gen5 502.He banged it on instal and it is out of balance now. Please help, he needs to run with us and watch SOTW. Please help.
MitchStellin is offline
Old 07-08-2004 | 05:05 AM
dyno's Avatar
Charter Member #655
Default Re: Dyno Needs A Balancer
got one coming next day air from summit....thanks mitch!
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 07-08-2004 | 06:06 AM
Dyno-- what about an istaller/removal tool? In a prior life when I was building my own motors, I got friendly with a couple of Tool and Die Makers. They'd mike my crank snout,make a keyway to insert in the keyway slot and ever so slightly hone out the balancer so it was still a relatively tight fit, but you didn't need the force of the world to get it on--or off. They did the same thing to my driveshafts/halfshafts. You can't go crazy,but a winter project that makes life a lot easier during the summer.Again, don't go crazy if you do this. Plus Loctite the bolt on the front of the crank and check it occaisonally if your not using it to adjust valves, etc. Hope you're running for the weekend. Sounds like you aged a few years this week!--Lou
Lmarth is offline
Old 07-08-2004 | 06:24 AM
dyno's Avatar
Charter Member #655
good Idea Lou...and yea I lost some hair this week!!!
dyno is offline
Old 07-08-2004 | 06:53 AM
Dyno- Many of the drag racers on this site know that you have to be careful with those harmonic balancers. It's easy to break the elastomer bond between the inner and outter rings. If you're lucky, you'll suddenly find that your timing marks are way off. If you're unlucky, they have been known to disintegrate (not good in a boat out on the water). A lot of race boats have boilerplate under the motors in case a motor grenades. Scary thought, ain't it?--Lou
Lmarth is offline
Old 07-08-2004 | 06:59 AM
dyno's Avatar
Charter Member #655
I've had enough problems I dont need to sink the biotch too!but a sparkler in the gas tank has crossed my mind several times this week!!!
dyno is offline
Old 07-08-2004 | 08:20 AM
Official OSO boat whore
I put a little oil on the snout/threads and then just pull it on with the center bolt. Sometimes I need to get a longer bolt to get it started.
Cord is offline
Old 07-08-2004 | 08:22 AM
rchevelle71's Avatar
CAREFUL!!!!!!!
I have pulled the threads out of the crank(on a small block) using this method.
rchevelle71 is offline
boatguy94
4
06-28-2008 11:33 AM
puder
6
03-21-2003 02:32 PM
nobudget
1
04-09-2002 06:34 PM
sheikman
2
04-01-2002 10:15 PM
