How Much Horsepower Will Merc # 5 Hold >
Old 07-11-2004 | 02:43 PM
Default How Much Horsepower Will Merc # 5 Hold
thinking of putting 5 drives on my new 39v with 800sc motors. not comfortable with any type of bravo drive and 6 is too expensive. have looked at the new 4x4 and merc 5. will it hold up and will it hold resale value and be worth more than xr drives?. does the 5 throw a roostertail like the 6 and does it come with steering incorporated into the drive? thanks
Buddy OO is offline
Old 07-11-2004 | 03:37 PM
Pete B's Avatar
Charter Member#203
Veteran: Navy
Default Re: How Much Horsepower Will Merc # 5 Hold
The 5's are rated for 750, but more power has been put to them. as for the steering you will need to purchase that separate.
Pete B is offline
Old 07-11-2004 | 03:48 PM
X-Rated30's Avatar
Arneson.
X-Rated30 is offline
Old 07-11-2004 | 07:02 PM
number 5 drives have been handling 840 hp for about 5 yrs now, no problems at all
Scooter is offline
Old 07-11-2004 | 07:21 PM
Ron P's Avatar
Enjoy the show
Get the Huber trans to put infront of the 5, it makes for a nice solid drive system.
The roostertail your talking about comes from one or both of the following. A staggered engine setup so the drives are real close together. Drives mounted so the prop sufaces with lots of power.
Forget the 4x4 when compared to a 5. Or just pay for the 6 and be done with it.
Ron P is offline
Old 07-11-2004 | 07:25 PM
I'm with Ron P. I've got 800SC's in front of Huber 1330"s and SSMV's with Mayfair Steering and lab finished props. Couldn't be happier.--Lou
Lmarth is offline
Old 07-11-2004 | 07:56 PM
Johnny DCB's Avatar
Where can I find some pics of #5 setups and the trannys?How hard is too switch from a bravo 1 set up over to a #5?
Johnny DCB is offline
Old 07-11-2004 | 08:09 PM
dlbCheckmate's Avatar
Whats the cost differance between the 5's and 6's ? Do they still sell the 5's new ?
Switching from Bravo's to # 5's would be starting over completely as you would have to move the engines to make room for the trannies. If switching from Bravo's I would seriously consider the Arnesons.
dlbCheckmate is offline
Old 07-11-2004 | 08:50 PM
pm board member JASSMAN ,think he is selling a set of 5's. as for switching from bravo to anything else with a tranny ,engine relocation forward , transom work ,exhaust outlet work ,alot of work check this months issue of powerboat , did a artical on the arneson /bravo . very good reading and info. but it also require alot of work , lowering engines , moving them forward, etc.here is a pic of #5's in action in the old lolliepops boat that JASSMAN bought at about 100mph. nice tail this was behind KE 1000's
open87 is offline
Old 07-11-2004 | 10:34 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
The engines do not move forward with the Arneson Bravo Conversion Kits.
The engines might drop lower in the boat, but that depends upon the current "X" dimension of the boat.
Our drive package requires less HP to operate and also weights far less, not to mention the cost vs. the Mercury SSM#5.
We have made a propeller cover so that no one will be impaled if they jumped off the back of the boat and landed onto the propeller.
Rik is offline
